Pics of G-body LS1 swap
Old 10-23-2008, 06:28 PM
Formula_LT1's Avatar
Default Pics of G-body LS1 swap
I thought I would post up some pics and info of my LS1 malibu swap. The tranny isn't in, so the oil pan looks closer than what will be, but I snapped a few shots of the pan clearence and fire wall. The engine is a 5.7 LS1 with a stock F-body (camaro/firebird) oil pan. I bought the 1" set back engine mount plates from The Car Shop inc. which worked out great. And the engine mounts are stock v-8 SBC mounts. I haven't bought headers to check clearence issues, but I've heard pacesetter long tubes work out okay.
Hope this helps anyone doing a gen III+ swap into a G-body.
Old 10-23-2008, 06:34 PM
grey95buick's Avatar
don't look to close to me!~....looks about perfect!
love those cars...have any full car pics?....hows the rear frame?
Old 10-23-2008, 06:40 PM
Yea, I have a fewpics of the car, none that are full car, but I'll dig up a few.
The rear fram is not perfect, has a few spots in the normal areas, but not bad at all. I think maybe 2-3 places the size of a dolar bill. Could be patched up no problem.
Old 10-23-2008, 06:43 PM
The doors are on it now, but I don't have any good pics of it yet. I'll try and get a few some day.
Old 10-23-2008, 06:47 PM
One more
Old 10-26-2008, 12:42 AM
pmgm's Avatar
Default Nice
Please keep us posted. I'm colecting parts for my LS1 Lq4 swap now.
Old 10-26-2008, 03:24 PM
I def. will. When I first started gathering info on gen III swaps in g-bodys, I never could get a straight answer about what type of oil pan with what type of engine mounts, so once now that I know what works, I thought I'd post it up so anyone else going the same route would know as well.
Old 10-26-2008, 04:12 PM
oxford03cobra's Avatar
thats a cool swap i always like those malibus they look a lot like the fairmonts
Old 10-26-2008, 05:21 PM
magic's Avatar
Nice build!
Old 10-26-2008, 05:34 PM
bgblockelcamino's Avatar
just working on tuning my car now. i have lq4/4l80e in my 86 el camino.
it is a different car now. a lot different than the big block that i had in there.
yours is looking good!
Old 11-02-2008, 07:43 PM
Thanks for the compliments guys!
Old 11-09-2008, 10:53 AM
84Ttype's Avatar
so what oil pan,engine mounts you go with? and what headers are you thinking?
Old 11-09-2008, 12:02 PM
magic's Avatar
first post says he used the LS1 F-body oil pan and car shop inc. motor mounts....
sometimes depending on the brand of motor mounts, Ive seen g-body swaps use the CTS-V oil pan, because it provides better clearance between the cross-member. Or some people will notch the cross member to get better clearance....
Old 11-09-2008, 12:18 PM
PaulC's Avatar
look at all the room in the engine bay!
Old 11-09-2008, 05:15 PM
NemeSS's Avatar
no need for headers
time for big single
Old 12-05-2008, 03:18 PM
ces63ss's Avatar
couple questions for you:
1. what intake are you going to run(fuel injected or carb)?
2. how or were did you order a harness to adapt to the cars electrical.
thanks
Old 12-06-2008, 09:03 AM
Roller406Bu's Avatar
i posted what works on here and maliburacing.com
Old 03-28-2009, 04:04 PM
03supercharged's Avatar
When using the 1 inch setback mounts, will the truck manifold clear the firewall?
Old 03-29-2009, 06:14 AM
deuce_454's Avatar
uou will need to notch the heater/AC box and/or move the rear coil in the passenger side if setting back the engine... but that sure beats notching the x-member or oilpan
Old 03-31-2009, 03:12 PM
samh_08's Avatar
Just thought I would show you guys a couple pictures of my setup. Enjoy
Quick Reply: Pics of G-body LS1 swap
