Where to buy Sand Blasting Media?
Old 10-15-2008, 05:31 AM
Stampede4ever's Avatar
Default Where to buy Sand Blasting Media?
Looking for Dupont's Star Blast, where to find it?
Thanks.
Old 10-16-2008, 10:06 PM
spills's Avatar
not sure about the specific brand, but I know Northern Tool carries a few different types.
Old 10-17-2008, 08:21 AM
Camaroholic's Avatar
I don't remember if Northern has Star Blast in particular, but they have several different non-silica based blasting materials available.
Old 10-18-2008, 10:51 AM
Motorboater
SilverGhost's Avatar
harbor freight has media if they have a store by you.
Just use an online yellow pages and search abrasives and call the companies that come up close to you until you get one that carries blast media. That's what I did to find my supplier.
Old 10-18-2008, 11:01 AM
6 & 8 Second Club
mrdragster1970's Avatar
In a pinch, most of the big lowes/menards type stores stock silica sand. Not name brand, but same basic item.
Old 10-22-2008, 04:21 PM
Motorboater
do NOT use silica. When blastedand released into the air it can cause some serious health problems if inhaled. If you do use it you need to be mondo protected. If should never be in a blast cabinet regardless of your reclamation system.
Old 10-22-2008, 07:34 PM
cbrracer's Avatar
You could always go to Eastwoods.com
They carry alot of differnt types of blasting media.
Good Luck,
Don
Old 10-22-2008, 07:40 PM
spills's Avatar
I've always been told never to use silica sand from home depot or anything, but I've never heard of not using it in a blast cabinet. Can you elaborate? Id never use it anyways, just curious why it can't be used in a cabinet. I would assume that if it's well ventilated (read: exhaust directed outside shop), there shouldn't be a problem.
Old 10-22-2008, 10:19 PM
Motorboater
I think it falls under the better safe than sorry directive. I know my cabinet has a warnign label on it that says not to use it in the cabinet.
Also depends on what you are using the parts for. as a powder coater i wouldn't use it, good chance it would leave **** in the metal that would mess up my coating.
Old 10-22-2008, 10:44 PM
6 & 8 Second Club
Wow, sorry for bad info. That is what I was taught. What is the actual use for it?? if anyone knows.
I still have several bags under a shelf. I bought 10 bags of the black stuff, and just pushed it to the back,
for emergency use.
Old 10-22-2008, 11:08 PM
spills's Avatar
Just look on the bag, I think what he's talking about is play sand. If it sand that was manufactured for blasting, then it's more than likely silica free and cool to use.
Theoretically, I think you can use silica sand, but you MUST use a good breather. Personally, I dont mind paying $9/bag for blasting media so I dont even risk it. I've heard all sort of horror stories of people use play sand on the job site only to to die from it (I forget the details, I think the silica sticks to your lungs or something). Plus, play sand is full of all sorts of different size granuals and can clog up very easy of not sifted through. Blasting sand is usually cut down pretty level as far as consistency goes with the size.
Old 10-23-2008, 07:47 AM
Motorboater
yes, there is no consistency in play sand, it will clog a blaster.
The health condition is called silacia as I recall, caused by inhaling the silica.
Spills I got your PM I will answer it today
Old 10-24-2008, 10:19 AM
6 & 8 Second Club
Ok, I did some checking. Silica sand was used for blasting for years. Nobody had any idea it was bad,
until workers started getting ill. It is still used world wide for blasting, but here in the US,
it must have a warning label saying highly recommended to use respiratory equipment while using.
My stuff must be old as dirt, due to it's in paper bags & has no label other than silica sand.
Again, sorry, I'm old & had no idea I was doing something stupid. AS USUAL.
Old 10-28-2008, 06:33 PM
Anyone heard of
www.ati-blackdiamond.com/new/shockrock.htm
What are the Cons?
Thanks.
Old 10-28-2008, 06:42 PM
trailwart's Avatar
not sure about the brand in question, but i have found media supplies at my local building stores/ lumber/hardware stores.
Old 10-28-2008, 06:50 PM
I can purchase this at TSC.
Thanks.
Quick Reply: Where to buy Sand Blasting Media?
