Old 05-26-2016, 04:18 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Chevrolet Camaro or Pontiac Firebird Fuel System Guides
Print Wikipost
How to run your LS1 on E85
Old 03-15-2008, 10:34 PM
  #201
Juje's Avatar
Originally Posted by fil131
No you cannot(well not just with a tuning program alone)
If you just tune with LS1-Edit, HPTuners, EFILive... You are flaching a set tune for the parameters you set, like AFR, Spark, Fueling... all set for the fuel you are currently using. Any more than 15% Gasoline per 85% Ethonol will change the values needed to have a good tune.
I have heard/read that there is a module that can be purchased that can read the Gasoline to Ethonol ratio, and send that ratio to your pcm, and with the parameters set correctly you could run anything from E100(pure ethonol) to straight Gasoline and anywhere in between. I think I've heard of one from bosch, but I'm sure there are more out there.
I actually would like to find one of these modules, if any of you know where I can find one please let me(all of us) know. I would like to start utilizing E85 but there is only one station within 15 miles of my house and not another in sight, so the module would be the way to go for me.
Hope my info helped Juje
Yeah, this answered my question and then some. Thanks
Old 03-16-2008, 02:19 AM
  #202
vaticano's Avatar
Finally got dynoed again. Bigger filter, injectors, two pumps and some timing, picked up 80 hp
Old 03-30-2008, 09:58 PM
  #203
DirtyJohn's Avatar
I'm curious if the Ford SVO 30lb Red Tops alone on a stock fuel pump would be strong enough to push enough fuel for a cammed/bolt on 346 LS1?
I'd love it if I could convert without a new fuel pump and injectors.
I've got all the software to eventually make it work without hopefully blowing it up.
Anyone care to comment?
Thanks for any info.
Great thread BTW!
I'm seriously considering a conversion this summer.
Being in Minnesota we have plenty of E85 pumps to make it worthwhile.
We're currently $.60 cheaper than gasoline so I'm really wanting to do this.
~Mot
Old 03-30-2008, 10:08 PM
  #204
vaticano's Avatar
It would really depend on the cam, and how much hp you make. The good thing about the E-85 is even if it runs lean at WOT it still wont knock or detonate. When my fuel system wasn't up to par I was running at an AFR of 14:1 at 6000 rmp WOT, and logged no KR. But you would need at least a new fuel pump, the stock one is pretty small and 42# injectors would be better.
Old 03-30-2008, 10:18 PM
  #205
Irocss85's Avatar
ditto. Id say atleast 42lbers and a better fuel pump. poss. an addon exernal pump would be ok.
Old 03-31-2008, 07:40 AM
  #206
cendres's Avatar
Upgrade the in-tank and go no smaller than 42's. If you have additional modification plans, go even larger on the injectors to give yourself some headroom for the increased fuel demands the later combination will present.
Old 03-31-2008, 11:07 AM
  #207
DirtyJohn's Avatar
Thanks guys.
Don't know if the pricetag is going to justify the swap needing both a pump and injectors.
Bummer, I really want to do this too.
Although it can't hurt to upgrade those parts anyways.
Knew I shoulda got bigger when I bought the 30lb'ers.
Old 03-31-2008, 01:06 PM
  #208
Runn's Avatar
Originally Posted by DirtyJohn
Thanks guys.
42 and pump and you will be fine
Old 04-01-2008, 07:32 PM
  #209
01slowbird's Avatar
has anyone had any problems with e85 pulling moisture from its surroundings and causing water in the gas tanks?
Old 04-01-2008, 08:03 PM
  #210
vaticano's Avatar
I never checked to see if there was water in the tank, but the car sat for two months without driving it with 1/2 of a tank and ran fine when I took it out. Although I do live in a dry enviroment we usually see 10-15 % humidity.
Old 04-02-2008, 09:05 AM
  #211
01slowbird's Avatar
ok that kindof answers one question i had. the other big question i have is what do you do in winters months with they drop the content to 70/30 ish? retune or what? most people dont drive in the winter months anyway, including myself, but on a 'warm' day i do like to start my car and take it for a quick drive.
Old 04-02-2008, 05:06 PM
  #212
vaticano's Avatar
The o2 sensors/fuel trims should compensate for the extra gas making it rich but I'm not 100% positive. I run in Open Loop SD.
Old 04-02-2008, 05:50 PM
  #213
sworaz's Avatar
Hmmm thought someone made a very strong argument against this on ls1.com ...
Old 04-02-2008, 05:52 PM
  #214
sworaz's Avatar
Oh yes there it is: Someone thinks it's an extremely bad idea.
http://www.ls1.com/forums/showthread.php?t=33448
Old 04-03-2008, 06:05 AM
  #215
01slowbird's Avatar
that dudes panties were a lil bunched up that day, he was trash talkin from the git go. where he might have had some good points of intrest or similar questions as i did, once he downed tech and praised ls1.com i just stopped reading...besides i want some answers from people that actually drive on e85.
Old 04-03-2008, 09:39 AM
  #216
camarols1's Avatar
I have run E85 on my last procharged SBC with awesome results.
The only time moisture is a concern is if the car is outside with a vented gas cap.
With all the emission equipment in place you should not have a problem.
Old 04-03-2008, 11:23 AM
  #217
99blancoSS's Avatar
Can someone recap this for me. I dont have time to read all 11 pages. e85 ok to run? anything to need to done to compensate for it? is it compresion happier? or better to run less compression?
Just a quick synopsis would be great
Old 04-03-2008, 12:22 PM
  #218
sworaz's Avatar
Cliff notes please
Old 04-03-2008, 12:39 PM
  #219
SmokinU's Avatar
I believe most questions were answered or atleast highlighted in the first page of the read.
Old 04-03-2008, 05:08 PM
  #220
vaticano's Avatar
Run it you wont be sorry. I have local guy here who does dyno/tune days, his set up is similar to mine but runs 15#'s of boost and only makes 20 rwhp more than myself at 10#'s. He even commented that if he ran the kind of timing I am he would blow the heads off his car. I got my timing table from EPP with my D1SC and after my first dyno added some tiiming and at 4400 rpm I picked up 200 rwtq and 170 rwhp. My peak numbers at 6000 rpm went up 80. You can see the results here for yourself this is the first dyno http://www.fquick.com/garages/viewga...wimg&id=117731 and here is the new one. http://www.fquick.com/garages/viewga...wimg&id=117732 Part of the increase was due to me picking up 1.5# of boost at 6k rpm. All you have to do to run it is change the STOICH AFR value, in your prefered tuning software, from 14.63:1 to 9.8:1. Assuming you have bigger fuel njectors and fuel pump. If you don't have a big enough fuel system it will run lean. But running lean with E-85 is not as bad as with gas.
Quick Reply: How to run your LS1 on E85
